More frequent inventory updates
Hi,
Right now, if I go under Show More-> Inventory, I can’t adjust how often it runs.
Allowing customizing to the frequency of the daily inventory task would help us have more accurate endpoint data.
ThankS!
I’d like to be able to do more frequent everything, but they’re going to hit a resource limitation eventually. We were pushing ours quite hard until we moved into the next tier as-is with daily maintenance.
Right, I get that. I would love to be able to run many deployments more often, but it’s not scalable, like you siad.
I’m just asking for an element of that, hence the request :slight_smile:
