Sequence of installs
It would be great if there was a way to sequence the installs of some applications in the global library.
example:
We run multiple versions of Autodesk software, and some do not like to be installed out of order.
Since all of the software in the global library is not editable there is no way to create a Prerequisite to the install.
The only other way I have been able to do this is to manually deploy the software one at a time.
Set the ordering in Immy and that will handle this for you!
Please elaborate. I don’t see any way in immy-bot to do this.
I don’t have that option.
Doesn’t sound like you have MSP admin access. Talk to your MSP Admin and they can get it sorted for you.
