System Update Confirmation Box
Problem:
Right now, if you click “System Update,” it immediately skips ahead without warning. That can be frustrating if you accidentally click it, especially since the button looks exactly the same as the “Release Notes” button. Because the two are the same color and right next to each other, it’s really easy to mis-click when you’re just trying to read the notes.
Suggested Fix:
Add a quick pop-up asking something like: “Are you sure you want to move to the next System Update?” with Confirm/Cancel.
Even better, give the “System Update” button a different look (color, icon, or something) so it stands out from the “Update Release Notes” button.
