Web Threat Shield Chrome Extension with Webroot keyCode
How we can enable the keycode option in the Immy task to enable the Web Threat Shield Chrome Extension in Chrome. The enable code to extension is already done but to activate that, we need to enter the Webroot site keycode. How we cna acheive this and have the option during the task deployment ?
@Amanpal_Singh if you enter the code in manually from the UI do you see it end up anywhere in the registry?
My bet would be there will be a registry key or maybe an XML file something like that where the serial might be getting stored. If you can find that a configuration to set the value could be possible.
