I was curious if anyone else has experience with this. I tried using ODT to create a 32bit configuration for M365 enterprise, but I’m struggling with understanding how I can script this.
I need it to run silently without any interaction from the end user, as I believe that’s what is causing the default OfficeSetup exe to fail. I got the scripts for uninstalling the default apps working, this is the last piece I need. Some users require 32bit Office to run some add-ins and connectors, so I’d like to give this as an option.
