Add immybot coexistence with agents from another organization
Since Immybot has become so useful in our onboarding / offboarding process, we often will use to bring in our RMM and security agents. We have not encountered it yet, but can ImmyAgent coexist with other instances of the app in other tenants in other orgs?
2 questions
1 - can ImmyAgent be used with another agent on a system (or must the other ImmyAgent be removed prior?)
2 - what happens if no ImmyAgents are used but two Control agents are present perhaps and two orgs have access via Immybot integration? What conflicts or issues would we see?
I didn’t do this personally, had co-workers who had similar situations.
I am pretty sure that ImmyBot’s agent is not fingerprinted and thus, there can only be one IB agent on a computer at a time.
I am pretty sure that issuing commands via two separate IB instances and two separate control instances works fine. You wouldn’t really want overlapping deployments if you can help it but I believe it works.
