Add parameter for "Device Group" to Sophos Endpoint Agent software
Hi - Sophos Endpoint has an option to set a device group when running the installer. Having the ability to set this in a deployment or onboarding would be very helpful to us. The command line option looks like the following:
--devicegroup="Your Group Name"
The full list of options is found here: Installer command-line options for Windows - Sophos Central Admin
We unfortunately can’t set this easily after initial install, as it seems Tamper Protection prevents us from just running the setup executable again, and we can’t see a way to dynamically retrieve a tamper protection password and turn it off.
Many thanks!
