When deploying configurable tasks (i.e. Printers, WiFi, Network Drives, etc.), it would be nice to be able to add deployment notes while we’re creating the deployment so we can help differentiate the task from another one without needing to drill-in to each deployment to find the correct one to edit.
As far as I know, the only way to add a note is to edit the deployment after it is created.
Create Deployment (no notes field😞):
Edit Deployment (notes field🎉):
Example with no notes:
Example with notes:
