Adding Edge, Chrome, Firefox security setting parameters
Edge Security settings:
I can only upload one embedded image since I am in a new user status, but there are similar security settings on all three browsers.
@William_Swartz do you happen to have any references to suggest these can be set by registry or some other method on all 3 browsers?
Here’s Edge, which usually means Chrome can too:
Windows Registry Settings
  • Path (Mandatory): SOFTWARE\Policies\Microsoft\Edge
  • Path (Recommended): N/A
  • Value Name: EnhanceSecurityMode
  • Value Type: REG_DWORD
@Bezalu_CTO that looks like it might be it, have you tested it by any chance?
Enable or Disable Enhanced Security Mode in Microsoft Edge Tutorial | Windows 11 Forum (elevenforum.com)
I had stumbled across this and seems to match up.
Not yet, I can make a quick task with params that changes it, though.
I’ll post back here tomorrow w results
