Adjusting Default Timeout
Is it possible to adjust the default timeout period for specific tasks? One use case is the Adobe Acrobat/ Reader Global software install task. It successfully installs the software but immybot gets hung during execution and sits there for 1800 seconds until it times out. Adobe should never take more than 5 minutes to install and the timeout should trigger much sooner than 30 minutes.
this is available under “Show More” - Preferences, under the “Scripts” section:
