Allow tenant to be specified to installer with simple text string
Rather than needing to create a new powershell command for each tenant with unique ids, I’d really like to be able to just specify the tenant name via a simple text string parameter along with some other kind of key to identify my MSP.
This should probably be the case for the rest of the fields you select on download, for a lot of the same reasons a configuration task in Immy exists. With paramater-based options for all of these things, we can use one script with easy to modify variables that will control how the deployment works.
