Autodesk uninstall scripts in global library
The uninstall scripts tied to Autodesk products in the global library are not working for all Autodesk software. Since Autodesk likes to change how there software is installed and uninstalled every few years I would suggest updating the uninstall scripts for the install methods that are being used for the product year. Most of the time there is a mismatch between what Immy.bot is expecting for a software title and what Autodesk is currently using. Example.
Uninstall: Autodesk Navisworks Manage 2026.
Immy.bot looiks for: Autodesk Navisworks 2026
Autodesk ODIS calls it: Autodesk Navisworks Manage 2026 - English
