Hi there! Been busy! Let me see if I can put this together for you.
Please note: We have the Cisco AnyConnect/Umbrella hidden from the programs/software list on the devices. You can change that piece of the installer script if you are okay with that appearing. Because of this, the version detection screenshot below will not actually show any software listed.
ALSO: This is for the Umbrella Module & the VPN showing. If you don’t want the VPN to show, you can edit the installation file with the flag to hide it (Cisco’s webportal provides this). And then you just have to remove the bits in the Configuration about the HostName/HostAddress & remove that script.
Zip your CORE & Umbrella MSI files into a zip folder - this will be the software that you put into ImmyBot software creation & when updating the software.
SOFTWARE PAGE:
Software Info:
Version Detection:
Install/Uninstall:
NOTE: We were using the old version of the Cisco Umbrella Roaming client, so we have a pre-req to uninstall that old version. I also have the DART application installing here. Though, with some edits to the below installation script & leaving that MSI file in the ZIP folder, you can just have it install with everything else here.
Configuration Task:
NOTE: The configuration script above, is just the Global script that is available to everyone, so I will not be posting it here.
SCRIPTS:
Installation Script:
Invoke-ImmyCommand {
$InstallerFolder = $($Using:InstallerFolder)
$MSIFolder = Get-ChildItem -Path $InstallerFolder
$InstallerFolder = "$InstallerFolder\$MSIFolder"
$organizationId = $($Using:organizationId)
$fingerprint = $($Using:fingerprint)
$userId = $($Using:userId)
# Create a search pattern to find the MSI file, assuming the base file name starts with 'cisco-secure-client-win'
# allowing for any characters in between
$searchPattern = "cisco-secure-client-win-*.msi"
Write-Host "Installer folder: $InstallerFolder"
# Get all of the MSI files names using the pattern
$msiFiles = Get-ChildItem -Path $InstallerFolder -Filter $searchPattern
Write-Host "MSI Files: $msiFiles"
# Check that the MSI files are found
# Note: if you are adding any other modules including the DART module, you will need to change this number.
if (!($msiFiles.Count -eq 2)) {
throw "Expected MSI installers not found in $InstallerFolder"
# As we are looking for specific MSI files, we find them with the below scripts
# They are written to the console for debugging purposes.
$AnyConnectMSI = $msiFiles | ? {$_.FullName -like "*vpn*"}
Write-Host = "AnyConnect: $AnyConnectMSI"
$UmbrellaMSI = $msiFiles | ? {$_.FullName -like "*umbrella*"}
Write-Host = "Umbrealla: $UmbrellaMSI"
# Log file path is hardcoded as per the requirement
$logFilePath = "C:\programdata\Cisco-Secure-Client-output.log"
# Core AnyConnect VPN Application
try {
# Construct the command to run with the specified flags
$installCommandAC = "msiexec /package `"$InstallerFolder\$AnyConnectMSI`" /norestart /passive LOCKDOWN=1 /lvx* `"$logFilePath`""
# Execute the installation
Write-Output "Running installation command: $installCommandAC"
$executionResult = Start-Process -FilePath "cmd.exe" -ArgumentList "/c $installCommandAC" -Wait -PassThru
# Check the result of the installation
if ($executionResult.ExitCode -eq 0) {
Write-Output "Installation completed successfully."
# Install Umbrella Module if AnyConnect installed Successfully
Try {
$installCommandU = "msiexec /package `"$InstallerFolder\$UmbrellaMSI`" /norestart /passive LOCKDOWN=1 ARPSYSTEMCOMPONENT=1 /lvx* `"$logFilePath`""
Write-Output "Running installation command: $installCommandU"
$executionResult = Start-Process -FilePath "cmd.exe" -ArgumentList "/c $installCommandU" -Wait -PassThru
throw "Installation failed with exit code $($executionResult.ExitCode)."
# Define the paths directly
$umbrellaDirectory = 'C:\ProgramData\Cisco\Cisco Secure Client\Umbrella'
$orgInfoPath = "$umbrellaDirectory\OrgInfo.json"
Write-Host "Org ID: " $organizationId
Write-Host "Fingerprint: " $fingerprint
Write-Host "UserID: " $userId
# Construct the JSON content
$jsonContent = @{
organizationId = $organizationId
fingerprint = $fingerprint
userId = $userId
# Convert to JSON
$jsonData = ConvertTo-Json -InputObject $jsonContent -Depth 3
# Write the JSON data to OrgInfo.json
$jsonData | Set-Content -Path $orgInfoPath -Encoding utf8 -Force
} catch {
Write-Host "Installation of Umbrella module failed, exiting script."
exit
} catch {
Write-Host "Installation of AnyConnect MSI failed, terminating script."
exit
Uninstall Script:
NOTE: This also uninstalls the DART app, you can always remove this as needed.
$Umbrella = "Cisco Secure Client - Umbrella"
$AnyConnect = "Cisco Secure Client - AnyConnect VPN"
$Dart = "Cisco Secure Client - Diagnostics and Reporting Tool"
$AnyConnectSoftware = Detect-Software -SoftwareSearchString $AnyConnect | ? {$_.UpgradeCode -ne ""}
$AnyConnectUpgrade = $AnyConnectSoftware | Select -ExpandProperty "UpgradeCode"
#Write-Host $AnyConnectSoftware
#Write-Host $AnyConnectUpgrade
#Try to Uninstall the Umbrella Module
Try {
Write-Host "Uninstalling: $Umbrella"
Uninstall-Software -DisplayName $Umbrella
#Try to Uninstall the DART Tool
try {
Write-Host "Uninstalling: $Dart"
Uninstall-Software -DisplayName $Dart
#Try to Uninstall the AnyCoonnect VPN Module
try {
Write-Host "Uninstalling: $AnyConnect"
Uninstall-Software -UpgradeCode $AnyConnectUpgrade
} catch {
Write-Host "$AnyConnect uninstall failed."
} catch {
Write-Host "$Dart uninstall failed."
} catch {
Write-Host "$Umbrella uninstall failed."
#Cleanup Files
Write-Host "Cleaning up Cisco Folders/Files."
$PDPath = "$($env:ProgramData)\Cisco"
$PFPath = "C:\Program Files (x86)\Cisco"
if (Test-Path $PDPath) {
Write-Host "$PDPath Exits"
Remove-Item -Path $PDPath -Recurse -Force -Confirm:$false
if (Test-Path $PFPath) {
Write-Host "$PFPath Exits"
Remove-Item -Path $PFPath -Recurse -Force -Confirm:$false
Hope this helps!!
