I would like to see a few options added to the Bluebeam configuration task.
- command to re-install the Bluebeam printer
- command to set the default DPI output to one of the following options (150, 300, 600, 1200)
See command line options in link.
I’ve had a look, and this doesn’t appear to apply to newer versions–the document references Bluebeam 2016, and I’ve just checked a machine on one of my clients and the referenced PmMngr5.exe file does not exist in the relevant path in that version.
If you look in the current install folders the PbMnger5.exe is there. The corresponding version folder is the only thing that there article does not address. On my computer it is located here.
C:\Program Files\Bluebeam Software\Bluebeam Revu\20\Revu\PbMngr5.exe
