Good Morning Team Immy…
I noticed an issue with the configuration task for the Bluebeam Revu 21 deployment software. It looks like there is a hardcoded parameter for the ProgID that is using RedlinePDFfile as the ProgID to set. When I checked a PC with Revu 21 set as the default handler, it showed Applications\Revu.exe
as the ProgID. Is it possible to adjust this value?
Also, I don’t think it was actually setting all the values in the user profiles it was trying to set the ProgID for when running the configuration task. After running, none of the profiles showing as “undesired .pdf associations” had changed to the RedlinePDFfile value set in the script.
