BlueBeam Revu 21 - specifying RevuPreferences.xml location
Would be amazing if we could get an option when deploying BlueBeam to specify a path to a RevuPreferences.xml file, which would automatically configure preferences for the software.
More detail:
Exporting Revu Preferences
If you want to use a set of Revu Preferences across all or part of your organization, you can click Export in the lower left of the Preferences dialog and save them to a network share. The RevuPrefences.xml can be distributed by following the process outlined in the Revu Deployment Guide.
Basic silent installation that also deploys a specific RevuPreferences.xml file:
msiexec.exe /i “\MyServer\Bluebeam?Deployment\Bluebeam Revu x64 21.msi” BB_REVUPREFERENCES=\MyServer\Bluebeam?Deployment\RevuPreferences.xml /qn
