@Benjamin_Danet this has been tried before.
It doesn’t work from the SYSTEM context and only works when the user is logged in.
If your wanting to configure a default start menu/task bar best bet really would be to create the layout you want with the XML file and replace it over the default shell file:
Create an export your DefaultLaouts.xml and LayoutModification.xml files and replace the defaults with them located at \Users\Default\AppData\Local\Microsoft\Windows\Shell\
This means you won’t be using the GPO approach that keeps the start menu and taskbar locked, but there isn’t a way to manage it moving forward unless someone has found another method.
Works fine on Win 10 but I believe @Anthony_Birone had said these xml approach doesn’t work on 11.
