Customize OOBE settings when creating ppkg file
We are in Australia and have region issues on deployed devices when the OOBE is set to “America”. Would be good if we can change what the package configures when it completes the OOBE.
Weather this is in the “Install Agent” pop up menu, or able to change them under the preferences menus, either global or tenant levels.
Would also like to customise, and set globally the details for the initial administrator account (even though it gets deleted, our cyber security team have flagged it).
Not a solution, but a temporary workaround - you can unzip the .ppkg files with 7zip or the like and manually edit the OOBE and local account creation commands.
Additional settings for the .ppkg creation through ImmyBot would be nice
We are in oz and worked at length with a dev from immy who couldn’t resolve this. We have to run a bunch of powershell in a user context to tidy this up. Super annoying.
