Is anyone else seeing the default PDF Handler failing? I am using the Adobe Acrobat/Reader Global Software and trying to use the default PDF Handler set to True.
I have tried to bounce around to the other tasks in the library but none of them seem to work.
Just trying to set Adobe Reader as the default.
Did you add the new “Configure UCPD” task before running it? Microsoft added a new driver recently (called the User Choice Protection Driver) that prevents scripts from changing user defaults. This task can disable that driver so you can properly set defaults.
Thank you! @Dakota_Lewis . That was it. I knew I was forgetting something.
