Deploying Screenconnect to the correct site
Hi, I have been trying to get the screen connect/control deployment to go to the correct site when deployed.
I know that the way that you get computers into control is through this url : https://outreach.screenconnect.com/Bin/ScreenConnect.ClientSetup.exe?e=Access&y=Guest&c=&c=&c=&c=&c=&c=&c=&c=
This URL is modified so that after the first c= you put the company, then after the second c= you put the site, after the third c= you put the device type, etc.
I was wondering if there was a way to make it so that immy deploys into the correct site via the deployment. If not, would it be possible to make immy deploy this URL to a computer so that it opens the link?
Thanks in advance!
