This is more a convenience thing. I’m sometimes guilty of not reading things, or at least not all the way. For context, I typically use the “Configure Directory” task for domain joins or AAD joins. I recently learned the note advises not using it. I probably will anyway, since I like it, and turnaround is usually pretty fast when I assist with finding the actual error.
In any case, this got me thinking that maybe these notes should have the option for color coding. Right now, it’s just green, but it could be a bit more intuitive if, for example:
green = informational
yellow = advisory
red = caution
I think this would definitely help get my attention when the notes pertain to something that is important to read.
