Here is my updated Directory Migration 2.0 Script.
This will Migrate just ONE profile, this will NOT migrate all profiles on the machine.
Requirements:
Computer must be in Destination Tenant
Destination Tenant must be connected to Azure via Immy.
How it Works:
We flush out any known enrollments, Rename the Accounts folder in the AAD Broker across all users.
We Should be validating that there is no Autologon registry set, and remove that {{I need to double check this one, it may not have made it in }}
This works off the Immy Primary Person being set, and the Last Logged on User being registered in ImmyBot.
We will pull the Primary Person and then pull the User’s Entra GUID and convert to local SID.
We then Migrate the Last Logged on User’s profile to the Entra SID then join Entra AD.
Allow up to 15 minuets for inTune to do its registration before you do ANYTHING on the machine.
I recommend that you set the inTune Device Primary Person as soon as the device joins.
Once inTune shows the device as compliant, Log the user in, and enroll them into WH4B.
This from my calculations takes about 1/2 the time off the Profile Migrations.
I will look to see if I can in the near future, slip in AD and local user migrations.
This will NOT migrate multiple profiles, if you need that functionality, please use the ImmyBot Directory Migraiton script.
Known issues: Microsoft Consumer Accounts.
You can migrate the profile, but please remove Hello PIN/biometrics first.
You may also have to manually delete that User, we’ve had some oddities with devices that were connected to Consumer Entra.
If your device was MDE joined to the destination tenant, you need to off-board the MDE enrollment prior to profile migration, it seemed to cause it to fail to join Entra.
AutoPilot devices - Must be removed from source and destination tenants. Allow up to 1 hour for MS back-end database to process. You can re-add back to AP post entra join.
.SYNOPSIS
ImmyBot Metascript — Entra-Only Directory Migration (Primary Person)
.DESCRIPTION
Migrates the last logged-on local/domain user profile to the Entra identity
of the computer's assigned Primary Person in Immy. Performs pre-migration
cleanup of stale MDM/AAD registry artifacts before joining the device to Entra.
Idempotent behavior:
Test — Returns $true if device is already Entra-joined and profile is
migrated to correct identity. Returns $false if work is needed.
Use -Force to bypass the already-joined check.
Set — Executes only when Test returns $false. After Set completes,
Test runs again and should return $true.
Get — Reports current state. No changes.
Required Immy context:
- Computer must have a Primary Person assigned with a valid M365 email.
- Entra/M365 tenant must be linked to the Immy client.
Credits:
Jeremy Barnes - Network Essentials
James Gerring - Network Essentials
Darren Kattan - ImmyBot, LLC
Special Thanks to All the ImmyBot Staff & Immense Networks, LLC
[CmdletBinding()]
# ── Standard deployment parameters ────────────────────────────────────────
[Parameter(HelpMessage = "Controls reboot behavior after migration")]
[ValidateSet('Immediate', 'IfNecessary', 'Suppress')]
[string]$RebootPreference = 'IfNecessary',
[Parameter(HelpMessage = "Force migration even if device is already Entra-joined (useful for re-migrating profile or re-joining)")]
[bool]$Force = $false,
# ── TROUBLESHOOTING OVERRIDES ──────────────────────────────────────────────
[Parameter(HelpMessage = "TROUBLESHOOTING ONLY: Skip pre-migration registry cleanup.")]
[bool]$SkipPreMigrationCleanup = $false,
[Parameter(HelpMessage = "TROUBLESHOOTING ONLY: Skip Entra user existence check.")]
[bool]$SkipEntraUserValidation = $false
dynamicparam {
New-ParameterCollection -Parameters @(
Get-DirectoryTypeParameters -DirectoryTypeVariableName 'DestinationDirectoryType'
$DirectoryType = $DestinationDirectoryType
switch ($DirectoryType) {
'AzureAD' {
New-HelpText -Name "MappingHint" -HelpMessage "If the profile folder name does not match the UPN prefix in the destination directory, Immy will use the email address configured in the default Outlook profile."
Get-JoinAzureADParameters
New-CheckboxParameter -Name LimitToPrimaryUser -Position 6 -HelpMessage (@"
This only works in Hybrid Joined environments!
We ask Azure AD for the OnPremisesSecurityIdentifier of the primary user.
Then, we only migrate the profile associated to that user.
This is useful if you don't want to have to exclude all profiles that can't be mapped.
"@ | Out-Markdown)
'ActiveDirectory' {
New-JoinableDomainsDropDown
New-Parameter -Name StaticallyAssignDomainControllerAsDNSServer -Position 6 -Type 'Boolean' -DefaultValue $false -HelpMessage 'Useful for ensuring the machines can hit the new DC'
#begin
begin {
#region --- Helper: Write-StepLog ---
function Write-StepLog {
[string]$Message,
[ValidateSet('INFO', 'WARN', 'ERROR', 'VERBOSE')]
[string]$Level = 'INFO'
$ts = Get-Date -Format 'HH:mm:ss'
switch ($Level) {
'INFO' { Write-Host "[$ts] [INFO] $Message" -ForegroundColor Cyan }
'WARN' { Write-Host "[$ts] [WARN] $Message" -ForegroundColor Yellow; Write-Warning $Message }
'ERROR' { Write-Host "[$ts] [ERROR] $Message" -ForegroundColor Red; Write-Error $Message }
'VERBOSE' { Write-Host "[$ts] [VERBOSE] $Message" -ForegroundColor Gray; Write-Verbose $Message }
#endregion
#region --- Helper: Get-LastLoggedOnSID (local execution) ---
function Get-LastLoggedOnSID {
$result = Invoke-ImmyCommand -ScriptBlock {
$regPath = 'HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Authentication\LogonUI'
$lastUserSID = $null
try {
$lastUserSID = (Get-ItemProperty -Path $regPath -ErrorAction Stop).LastLoggedOnUserSID
} catch {
if ($lastUserSID -and $lastUserSID -match '^S-1-') {
return @{
Success = $true
SID = $lastUserSID
Source = 'LogonUI'
Fallback = $false
Error = $null
# Fallback: ProfileList scan
$profileListPath = 'HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList'
$profiles = Get-ChildItem $profileListPath -ErrorAction SilentlyContinue |
Where-Object { $_.PSChildName -match '^S-1-5-21' } |
ForEach-Object {
$props = Get-ItemProperty $_.PSPath -ErrorAction SilentlyContinue
[PSCustomObject]@{
SID = $_.PSChildName
ProfilePath = $props.ProfileImagePath
LastWrite = $_.LastWriteTime
} | Sort-Object LastWrite -Descending
if ($profiles) {
return @{
Success = $true
SID = $profiles[0].SID
Source = 'ProfileList'
Fallback = $true
FallbackInfo = @{
ProfilePath = $profiles[0].ProfilePath
LastWrite = $profiles[0].LastWrite
Error = $null
return @{
Success = $false
SID = $null
Source = $null
Fallback = $false
Error = 'Could not determine last logged-on user SID from LogonUI or ProfileList.'
return $result
#endregion
#region --- Helper: Get-ProfileBySID (local execution) ---
function Get-ProfileBySID {
param([string]$SID)
param([string]$TargetSID)
$profilePath = "HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList\$TargetSID"
if (-not (Test-Path $profilePath)) {
return @{
Success = $false
Error = "No ProfileList entry found for SID '$TargetSID'."
$props = Get-ItemProperty $profilePath
return @{
Success = $true
SID = $TargetSID
State = $props.State
} -ArgumentList $SID
return $result
#endregion
#region --- Helper: Get-DSRegStatus (local execution) ---
function Get-DSRegStatus {
$raw = & dsregcmd /status 2>&1 | Out-String
$status = [ordered]@{
AzureAdJoined = 'NO'
DomainJoined = 'NO'
WorkplaceJoined = 'NO'
TenantName = 'N/A'
AzureAdTenantId = 'N/A'
DeviceName = 'N/A'
EnterpriseJoined = 'NO'
# Iterate over a copy of keys to avoid enum modification error
$keys = @($status.Keys)
foreach ($key in $keys) {
if ($raw -match "$key\s*:\s*(.+)") {
$status[$key] = $Matches[1].Trim()
return $status
return $result
#endregion
#region --- Pre-Migration Cleanup (local execution) ---
function Invoke-PreMigrationCleanup {
param([string]$ProfileSID)
if ($using:SkipPreMigrationCleanup) {
Write-StepLog "TROUBLESHOOTING OVERRIDE — Pre-migration cleanup skipped." -Level WARN
return
Write-StepLog "========================================"
Write-StepLog "PRE-MIGRATION CLEANUP — SID: $ProfileSID"
$cleanupResult = Invoke-ImmyCommand -ScriptBlock {
$log = @()
$errors = @()
# ── 1. Clear MDM Enrollment keys ─────────────────────────────────────
$log += "Step 1/6: Clearing stale MDM enrollment records..."
$enrollmentPaths = @(
"HKLM:\SOFTWARE\Microsoft\Enrollments",
"HKLM:\SOFTWARE\Microsoft\Enrollments\Status",
"HKLM:\SOFTWARE\Microsoft\EnterpriseResourceManager\Tracked"
$enrollmentCount = 0
foreach ($path in $enrollmentPaths) {
if (Test-Path $path) {
$children = Get-ChildItem $path -ErrorAction SilentlyContinue
foreach ($child in $children) {
if ($child.PSChildName -match '^[{]?[0-9A-Fa-f\-]{36}[}]?$') {
try {
Remove-Item $child.PSPath -Recurse -Force -ErrorAction Stop
$enrollmentCount++
} catch {
$errors += "Could not remove enrollment entry $($child.PSChildName): $_"
$log += " MDM enrollment entries removed: $enrollmentCount"
# ── 2. Clear AAD Broker / WAM token caches ────────────────────────────
$log += "Step 2/6: Clearing AAD Broker / WAM token caches..."
$aadTokenPaths = @(
"HKLM:\SOFTWARE\Microsoft\IdentityStore\Cache",
"HKLM:\SOFTWARE\Microsoft\IdentityStore\LogonCache",
"HKCU:\SOFTWARE\Microsoft\IdentityStore\Cache",
"HKCU:\SOFTWARE\Microsoft\IdentityStore\LogonCache"
foreach ($path in $aadTokenPaths) {
try {
Remove-Item $path -Recurse -Force -ErrorAction Stop
$log += " Cleared: $path"
} catch {
$errors += "Could not clear $path : $_"
# ── 3. Remove stale AAD device registration keys ───────────────────────
$log += "Step 3/6: Removing stale AAD device registration artifacts..."
$aadDevicePaths = @(
"HKLM:\SYSTEM\CurrentControlSet\Control\CloudDomainJoin\JoinInfo",
"HKLM:\SYSTEM\CurrentControlSet\Control\CloudDomainJoin\TenantInfo"
$deviceRegCount = 0
foreach ($path in $aadDevicePaths) {
try {
$deviceRegCount++
} catch {
$errors += "Could not remove $($child.PSChildName): $_"
$log += " AAD device registration entries removed: $deviceRegCount"
# ── 4. Clear NGC / Windows Hello keys ────────────────────────────────
$log += "Step 4/6: Clearing NGC / Windows Hello credential provider keys..."
$ngcPath = "HKLM:\SOFTWARE\Microsoft\Windows\CurrentVersion\Authentication\Credential Providers\{D6886603-9D2F-4EB2-B667-1971041FA96B}"
if (Test-Path $ngcPath) {
try {
Remove-Item $ngcPath -Recurse -Force -ErrorAction Stop
$log += " NGC credential provider key removed."
} catch {
$errors += "Could not remove NGC key: $_"
$log += " NGC key not present — skipping."
# ── 5. Remove AAD Storage workplace join token from user hive ────────
$log += "Step 5/6: Removing AAD Storage workplace join token from user hive..."
$userHivePath = "Registry::HKEY_USERS\$TargetSID"
$workplaceJoinPath = "$userHivePath\SOFTWARE\Microsoft\Windows\CurrentVersion\AAD\Storage\https://login.microsoftonline.com"
if (Test-Path $workplaceJoinPath) {
try {
Remove-Item $workplaceJoinPath -Recurse -Force -ErrorAction Stop
$log += " AAD Storage workplace join token removed."
} catch {
$errors += "Could not remove AAD Storage from user hive: $_"
$log += " AAD Storage key not present in user hive — skipping."
# ── 6. Check if profile hive is loaded ───────────────────────────────
$log += "Step 6/6: Checking profile hive load state..."
$loadedHive = Get-ChildItem "Registry::HKEY_USERS" -ErrorAction SilentlyContinue |
Where-Object { $_.PSChildName -eq $TargetSID }
if ($loadedHive) {
$log += " WARNING: Profile hive for SID $TargetSID is currently loaded."
$hiveLoaded = $true
$log += " Profile hive is not currently loaded."
$hiveLoaded = $false
return @{
Log = $log
Errors = $errors
HiveLoaded = $hiveLoaded
} -ArgumentList $ProfileSID
foreach ($entry in $cleanupResult.Log) {
Write-StepLog $entry
foreach ($err in $cleanupResult.Errors) {
Write-StepLog $err -Level WARN
if ($cleanupResult.HiveLoaded) {
Write-StepLog "Profile hive is loaded. Reboot strongly recommended post-migration." -Level WARN
Write-StepLog "Pre-migration cleanup complete."
#endregion
#region --- Shared Prerequisite Resolution ---
function Resolve-MigrationPrerequisites {
#Connect to AzureAD
#Connect-ImmyAzureAD
$result = @{
PrimaryEmail = $null
EntraUser = $null
EntraUPN = $null
EntraGUID = $null
EntraSID = $null
LastSID = $null
Profile = $null
DSRegStatus = $null
AlreadyJoined = $false
# ── Resolve Primary Person (Immy server-side) ────────────────────────────
Write-StepLog "Resolving Immy Primary Person..."
try {
$computer = Get-ImmyComputer -ErrorAction Stop
$result.PrimaryEmail = $computer.PrimaryPersonEmail
} catch {
throw "Failed to retrieve computer record from Immy: $_"
if ([string]::IsNullOrWhiteSpace($PrimaryPersonEmail)) {
throw "No Primary Person assigned to this computer in Immy."
Write-StepLog "Primary Person email: $($PrimaryPersonEmail)"
# ── Validate Entra User (Immy server-side) ───────────────────────────────
if (-not $SkipEntraUserValidation) {
Write-StepLog "Validating Entra user exists..."
try {
$entraUser = Get-ImmyAzureADUser -identity $PrimaryPersonEmail -ErrorAction Stop
if (-not $entraUser) { throw "Get-ImmyAzureADUser returned null." }
Write-StepLog "Entra user confirmed: $($entraUser.DisplayName) | UPN: $($entraUser.UserPrincipalName)"
$result.EntraUser = $entraUser.DisplayName
$result.EntraUPN = $entraUser.UPN
$result.EntraGUID = $entraUser.Id
$result.EntraSID = $entraUser.SID
} catch {
throw "Is the Primary Person Set? Entra user lookup failed for '$($PrimaryPersonEmail)': $_"
Write-StepLog "TROUBLESHOOTING OVERRIDE: Skipping Entra user validation." -Level WARN
$result.EntraUPN = $result.UPN
# ── Check Current Join State (target machine) ────────────────────────────
$result.DSRegStatus = Get-DSRegStatus
$result.AlreadyJoined = ($result.DSRegStatus.AzureAdJoined -eq 'YES')
Write-StepLog "Current join state:"
Write-StepLog " AzureAdJoined : $($result.DSRegStatus.AzureAdJoined)"
Write-StepLog " DomainJoined : $($result.DSRegStatus.DomainJoined)"
Write-StepLog " WorkplaceJoined : $($result.DSRegStatus.WorkplaceJoined)"
Write-StepLog " TenantName : $($result.DSRegStatus.TenantName)"
Write-StepLog " TenantId : $($result.DSRegStatus.AzureAdTenantId)"
# ── Resolve Last Logged-On Profile (target machine) ──────────────────────
# Skip source profile resolution when already Entra-joined (post-migration),
# unless Force is set to allow re-migration.
if ((-not $result.AlreadyJoined) -or $Force) {
Write-StepLog "Resolving last logged-on user profile..."
$sidResult = Get-LastLoggedOnSID
if (-not $sidResult.Success) {
throw "Could not resolve last logged-on SID: $($sidResult.Error)"
$result.LastSID = $sidResult.SID
if ($sidResult.Fallback) {
Write-StepLog "Used ProfileList fallback for SID." -Level WARN
Write-StepLog "Last logged-on SID: $($result.LastSID) (Source: $($sidResult.Source))"
# ── Resolve Profile Details (target machine) ─────────────────────────
$profileResult = Get-ProfileBySID -SID $result.LastSID
if (-not $profileResult.Success) {
throw "Could not resolve profile for SID '$($result.LastSID)': $($profileResult.Error)"
$result.Profile = $profileResult
Write-StepLog "Target profile: $($result.Profile.ProfilePath) | State: $($result.Profile.State)"
Write-StepLog "Device already Entra-joined — source profile resolution skipped."
return $result
#endregion
#region --- METHOD SWITCH ---
switch ($method) {
# GET — Report current state. No changes.
"get" {
#Connect Azure AD
Write-StepLog "METHOD: GET — Reporting current state"
try {
$prereqs = Resolve-MigrationPrerequisites
} catch {
Write-StepLog "Prerequisite resolution error: $_" -Level WARN
Write-StepLog "CURRENT STATE SUMMARY"
Write-StepLog " Primary Person Email : $($prereqs?.PrimaryEmail ?? 'N/A')"
Write-StepLog " Entra UPN : $($prereqs?.EntraUPN ?? 'N/A')"
Write-StepLog " Entra GUID : $($prereqs?.EntraGUID ?? 'N/A')"
Write-StepLog " Entra SID : $($prereqs?.EntraSID ?? 'N/A')"
Write-StepLog " Source Profile Path : $($prereqs?.Profile?.ProfilePath ?? 'N/A')"
Write-StepLog " Source Profile SID : $($prereqs?.LastSID ?? 'N/A')"
Write-StepLog " AzureAD Joined : $($prereqs?.DSRegStatus?.AzureAdJoined ?? 'N/A')"
Write-StepLog " Domain Joined : $($prereqs?.DSRegStatus?.DomainJoined ?? 'N/A')"
Write-StepLog " Workplace Joined : $($prereqs?.DSRegStatus?.WorkplaceJoined ?? 'N/A')"
Write-StepLog " Tenant Name : $($prereqs?.DSRegStatus?.TenantName ?? 'N/A')"
Write-StepLog " Tenant ID : $($prereqs?.DSRegStatus?.AzureAdTenantId ?? 'N/A')"
return $prereqs
# TEST — Idempotent state check.
# Returns $true if device is already in desired state (Entra-joined).
# Returns $false if work is needed.
# Use -Force to bypass the already-joined check.
"test" {
Write-StepLog "Connecting to Azure AD in Test Mode"
#Connect Azure AD
Write-StepLog "METHOD: TEST — Checking desired state"
try {
} catch {
Write-StepLog "Prerequisite resolution failed: $_" -Level ERROR
return $false
# ── Force parameter bypasses already-joined check ────────────────────
if ($Force) {
Write-StepLog "FORCE parameter set — bypassing already-joined check." -Level WARN
Write-StepLog "Migration will execute regardless of current join state."
Write-StepLog "TEST RESULT: FALSE — Force migration requested"
return $false
# ── Desired State Check: Is device Entra-joined? ─────────────────────
if ($prereqs.AlreadyJoined) {
if (-not $prereqs.EntraSID) {
Write-StepLog "Device is Entra-joined but destination user SID was not resolved." -Level WARN
Write-StepLog "TEST RESULT: FALSE — Migration required"
return $false
Write-StepLog "Device is already Entra-joined."
Write-StepLog " TenantName : $($prereqs.DSRegStatus.TenantName)"
Write-StepLog " TenantId : $($prereqs.DSRegStatus.AzureAdTenantId)"
Write-StepLog " EntraSID : $($prereqs.EntraSID)"
Write-StepLog "TEST RESULT: TRUE — Already in desired state"
return $true
# Not joined — work is needed
Write-StepLog "Device is NOT Entra-joined."
return $false
# SET — Execute full migration.
# Only runs when Test returns $false.
"set" {
#Connect Azure AD
Write-StepLog "METHOD: SET — Beginning Entra migration"
if ($Force) {
Write-StepLog "FORCE mode enabled — proceeding with migration despite existing join state." -Level WARN
# ── Step 1: Resolve prerequisites ─────────────────────────────────────
Write-StepLog "STEP 1/6: Resolving prerequisites..."
try {
} catch {
throw "Prerequisite resolution failed — aborting: $_"
Write-StepLog "STEP 1/6: Prerequisites resolved."
# ── Step 2: Pre-migration cleanup ─────────────────────────────────────
Write-StepLog "STEP 2/6: Running pre-migration cleanup..."
Invoke-PreMigrationCleanup -ProfileSID $prereqs.LastSID
Write-StepLog "STEP 2/6: Pre-migration cleanup complete."
# ── Step 3: Migrate user profile ──────────────────────────────────────
Write-StepLog "STEP 3/6: Migrating user profile..."
Write-StepLog " Source profile : $($prereqs.Profile.ProfilePath)"
Write-StepLog " Source SID : $($prereqs.LastSID)"
Write-StepLog " Destination UPN: $($prereqs.EntraUPN) (AzureAD)"
Write-StepLog " Destination SID: $($prereqs.EntraSID)"
try {
$migrateParams = @{
ProfilePath = $prereqs.Profile.ProfilePath
SID = $prereqs.EntraSID
# DestinationSIDType = 'AzureAD' ##pulled out
#if ($OAuthInfo) { $migrateParams.OAuthInfo = $OAuthInfo }
Set-UserProfileOwner @migrateParams -ErrorAction Stop
Write-StepLog "STEP 3/6: Profile migration completed."
} catch {
throw "Profile migration failed: $_"
# ── Step 4: Entra device join ────────────────────────────────────────
Write-StepLog "STEP 4/6: Initiating Entra device join..."
Write-StepLog " RequireIntuneEnrollment : $RequireIntuneEnrollment"
try {
$joinParams = @{ RequireIntuneEnrollment = $RequireIntuneEnrollment }
if ($OAuthInfo) { $joinParams.OAuthInfo = $OAuthInfo }
if ($DEMUsername) { $joinParams.DEMUsername = $DEMUsername }
if ($DEMPassword) { $joinParams.DEMPassword = $DEMPassword }
Join-AzureAD @joinParams -ErrorAction Stop
Write-StepLog "STEP 4/6: Entra device join completed."
} catch {
throw "Entra device join failed: $_"
# ── Step 5: Post-join validation ─────────────────────────────────────
Write-StepLog "STEP 5/6: Validating post-join state..."
$postJoinStatus = Get-DSRegStatus
Write-StepLog " AzureAdJoined : $($postJoinStatus.AzureAdJoined)"
Write-StepLog " TenantName : $($postJoinStatus.TenantName)"
Write-StepLog " TenantId : $($postJoinStatus.AzureAdTenantId)"
if ($postJoinStatus.AzureAdJoined -eq 'YES') {
Write-StepLog "STEP 5/6: dsregcmd confirms Entra join. Tenant: $($postJoinStatus.TenantName)"
Write-StepLog "STEP 5/6: dsregcmd not yet showing AzureAdJoined = YES. Expected — will reflect after reboot." -Level WARN
# ── Step 6: Reboot handling ───────────────────────────────────────────
Write-StepLog "STEP 6/6: Reboot preference: $RebootPreference"
switch ($RebootPreference) {
'Immediate' { Write-StepLog " Immediate reboot scheduled." }
'IfNecessary' { Write-StepLog " Reboot if required." }
'Suppress' { Write-StepLog " Reboot suppressed — manual reboot required." -Level WARN }
Write-StepLog "SET COMPLETE — Migration finished for $($prereqs.PrimaryEmail)."
#endregion
#endbegin
