Im trying to switch a client from on prem AD to AAD using the immybot app, i was able to do it on a different device last week but now im not able to. Im getting the below error. I tried to reconsent and make sure that the secret is not expired but its still failing. Anyone seen this before?
"Global script ‘Directory Migration’ had a terminating error when run in Test mode
While processing Unable to connect to Azure AD, ensure Secret is not expired under Settings->Azure
The term ‘Connect-AzureAD’ is not recognized as a name of a cmdlet, function, script file, or executable program.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again."
