Our clients occasionally request reports on what is currently being deployed, it would be a nice feature to have in the deployments tab, to export to CSV, based on the filter criteria i.e. “Per Tenant”
@EDaniels What’s the export critera?
To generate a compliancy report across the estate, detailing the installed software and its current versions. For example, this report would encompass clients using Autodesk products, which may include multiple products and various versions across the stack. Hope it makes sense…
That might be better suited for the dashboard, then add all sorts of filters to select your paramters.
Like Tenants | Software name quantity | etc. I think they just need to add a lot more functionality to the Dashboard.
*The deployment table can now be exported to excel!
