Hi team,
We’re looking to automate app deployments. Currently the workflow is:
- user submits an app install request ticket
- a tech adds the user to the relevant security group for the app deployment
- the tech runs Immybot maintenance on the machine
- the app is deployed since the user is now part of the security group
We would like to eliminate tech involvement entirely. The ideal workflow is:
- request is picked up, probably by a Power Automate flow, and adds the user to the relevant group
- maintenance is run on the machine from the flow, e.g. via an HTTP endpoint, and the app is deployed like normal
- if the app is not compliant after maintenance is run, a ticket is created/updated for a tech to take a look (via Power Automate)
What’s the recommended approach here? Is this possible? (Mainly asking about the last two points above - we can figure out the first two).
Thanks,
Max
