Filter on CW Control for non supported OS
I have been looking for a resolution for the CW Control integration pushing installation onto devices that Immybot no longer supports. The best solution would be a filter in the integration that only pushes this onto devices that are supported by the application.
It doesn’t make sense to install this on devices that are not supported and there is not currently a solution that makes sense for MSPs within CW Control/Screenconnect that allows for filtering of those unsupported devices.
