Foxit Reader Configuration Task Not able to deploye
Random thing, not sure if anything has run into this before. I might just be missing something but when we go to deploy Foxit Reader to a customer the program installs fine but the configuration task that is attached to it fails and I am not sure why. We cannot add this task to the deployment at all nor can you deploy it from the tasks screen. Is there an additional task that needs to run for this to work, I have already tried duplicating it and modifying the current deployment to no success. Below is the output that I get:
Test Name Input Result --------- ----- ------ PDFHandler False False RemoveDesktopShortcut True True
Processing
5:34:13pm
The test still resulted in non-compliant after enforcing.
