Google Drive and syncing Desktop and Documents folders on Computer
Google Drive deployment looking for a way to push out and also link in the Desktop, Documents, and other folders similar to how OneDrive does it
@Timothy_Wachenfeld have you found any resources to suggest this is possible to do?
My googlefoo might be failing today but I didn’t find anything in a quick search.
I could not, was crossing my fingers maybe someone here found a way but it seems it doesn’t link the same way that onedrive does.
I was also trying to find some information on this but didn’t find much.
https://support.google.com/a/thread/153038126/google-drive-well-known-folders-on-login?hl=en
https://old.reddit.com/r/gsuite/comments/oaaj5v/redirecting_desktop_and_document_folders_to/
