We took an image of a thin client with Immybot Agent installed but none of the computers imaged are talking to Immybot even though the Agent is installed and running.
Is there a process for prepping Immybot agent to be installed via golden images?
You can use dism to inject the ppkg into the install.wim. This will essentially mean it will install when the device is powered on for the first time.
The problem with building it already installed into your image is the various identifiers it needs to differentiate devices.
That makes sense. We actually do this for Sentinel1 and a few other programs. Thanks
