Hey all, I’m experiencing issues with the Acronis Integration. This is the error i’m given,
" Health Check - This integration is experiencing issues.
ProviderConstructionFailedException: Unable to initialize the requested provider
→ HttpResponseException: Response status code does not indicate success: 500 (Internal Server Error). "
Has anyone else experienced this before? I went through and nothing seems out of line with the integration specifics.
Thanks, Reid. We’re aware of this issue. It’s actually on their (Acronis) end and they’ve got a fix scheduled for their 26.02 release. I asked for an ETA but haven’t heard back. When I do, I’ll make sure to give you an update.
Having the same isse.
Stuck in the same boat…
Anyone managed to create a manual deployment?
Heard back from Acronis. They have a hotfix slated for February 13th.
The hotfix was released. It appears to be working for a few instances I checked. Anyone able to confirm?
