If you want the SDB decompressed, install python prior to running.
Using the FU.WhyAmIBlocked Powershell module
switch($method){
"set" {
Write-Host "Checking to see if we have the minimum requirements of RAM."
$totalMemoryGB=Invoke-ImmyCommand {
$computerSystem = Get-WmiObject -Class Win32_ComputerSystem
return [Math]::Round($computerSystem.TotalPhysicalMemory / (1GB))
Write-Output "Total System Memory: $totalMemoryGB GB"
if ($totalMemoryGB -lt 8) {
Write-Error -Message "System memory $($totalMemoryGB) is less than 8GB." -ErrorAction Stop
Write-Output "System memory is sufficient (8GB or more)."
Write-Host "Going to Check for Disk space, Need at least 64GB free to be able to upgrade."
$freespacegb=Invoke-ImmyCommand{
$drive = Get-PSDrive -PSProvider FileSystem | Where-Object {$_.Root -eq 'C:\'}
return [math]::Round($drive.Free / 1GB, 2)
if ($freeSpaceGB -ge 64) {
Write-Host "C: drive has $($freeSpaceGB) GB free, which is more than 64GB."
Write-Error -Message "Houston, we have a problem. Not enough Diskspace: $($freeSpaceGB) GB < 64GB" -ErrorAction Stop
$SecureBootCheck=Invoke-ImmyCommand { return Confirm-SecureBootUEFI }
if(!$SecureBootCheck){
Write-Error "SecureBoot Not Enabled."
}else { Write-Host "System has SecureBoot enabled."}
Restart-ComputerAndWait
$uri = "https://go.microsoft.com/fwlink/?linkid=2171764"
$downloaduri = Get-RedirectedUri $uri
$upgradeAssistant = "C:\Windows\Temp\Win11Upgrade\UpgradeAssistant.exe"
Download-File -Source $downloaduri -Destination $upgradeAssistant -Force
$logFile = 'C:\`$WINDOWS.~BT\Sources\Panther\setupact.log'
$logFolder='C:\Win11UpgradeLogs'
Write-Host "Checking to see if `$Windows.~BT folder exists, and if so, remove it for clean run results."
Invoke-ImmyCommand -Timeout 14000 {
$logFile = 'C:\$WINDOWS.~BT\Sources\Panther\setupact.log'
$WindowsBT='C:\$WINDOWS.~BT\'
if (Test-Path -Path $logFile) {
#Take ownership of existing Panther file
#updated provided by CCP_Jason
takeown /f $WindowsBT /r /d y > nul
Write-Host "Ownership of '$folderPath' and its contents has been taken by System."
Write-Host "Panther setupact file already exists."
Write-Host "Removing $($WindowsBT) folder recursively prior to WUA launch."
Remove-Item -Path $WindowsBT -Recurse -Force
$FUPath='C:\FeatureUpdateBlocks'
Get-ChildItem -Path $FUPath -Directory | ForEach-Object {
Remove-Item -Path $_.FullName -Recurse -Force
Write-Host "Deleted FU Log directory, we want a clean log run each Immy run: $($_.FullName)"
Write-Host "Starting Windows 11 Upgrade Assistant. Can't stream the setup log as it kills Immy. We wil get the contents after Windows 11 update completes before we reboot."
Invoke-ImmyCommand -timeout 14400 {
$upgradeAssistant = $using:UpgradeAssistant
Start-Process $upgradeAssistant -ArgumentList "/quietinstall /skipeula /auto upgrade /NoRestartUI /SkipCompatCheck /dynamicupdate disable /PreventWUUpgrade /SkipSelfUpdate /priority normal /copylogs $LogFolder" -Wait
$LogFile=$using:logfile
Get-Content $LogFile
Invoke-ImmyCommand -Timeout 14400 {
$currentbuild=[int](Get-ItemProperty -Path 'HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion').CurrentBuild
if($currentbuild -lt 22000) {
$logPath = 'C:\$WINDOWS.~BT\Sources\Panther\setupact.log'
$errLogPath = 'C:\$WINDOWS.~BT\Sources\Panther\setuperr.log'
Write-Host "Checking for file $errLogPath`n"
if (Test-Path $errLogPath) {
Set-ExecutionPolicy Unrestricted -force -Confirm:$false
$errLogFileContent = Get-Content -Path $errLogPath -Force
Write-Host "$errLogPath found. Log contents:`n"
#Write-Host "$errLogFileContent`n"
Get-Content $errLogPath
#Sometimes Dell and Windows do not see eye to eye on BIOS updates, so let's check hidden Windows updates.
if (-not (Get-Module -ListAvailable -Name "PSWindowsUpdate")) {
Write-Host "Module 'PSWindowsUpdate' not found. Installing from PowerShell Gallery..."
Install-Module -Name "PSWindowsUpdate" -Force -Scope AllUsers -AllowClobber -confirm:$false
Write-Host "Module installed, now let."
Write-Host "Importing Windows update Module"
Import-module -Name "PSWindowsUpdate"
Write-Host "Now pulling Windows updates with Hidden updates"
Get-Windowsupdate -WithHidden -NotTitle "Windows 11" -Verbose
if((Get-ChildItem -Path 'HKLM:\SOFTWARE\Microsoft\NET Framework Setup\NDP' -Recurse | Get-ItemProperty -Name 'Version' -ErrorAction SilentlyContinue | ForEach-Object {$_.Version -as [System.Version]} | Where-Object {$_.Major -eq 3 -and $_.Minor -eq 5}).Count -ge 1){
Write-Host ".Net FX 35 installed, good"
}else {
Write-Host "Installing .Net 3.5, required to unpack SDB files"
DISM /Online /Enable-Feature /FeatureName:NetFx3 /All
#Let's See Why we are blocked with this lovley little Powershell module by AdamGrossTX
#https://www.powershellgallery.com/packages/FU.WhyAmIBlocked/1.0.0.9
#https://github.com/AdamGrossTX/FU.WhyAmIBlocked
# Check if the module "FU.WhyAmIBlocked" is installed
#but before we do that, we need to ensure that NuGet is installed, at at the minimimum version from my testing, 3.0.0.1
try {
# Check if NuGet provider is installed and its version
$nugetProvider = Get-PackageProvider -Name "NuGet" -ErrorAction SilentlyContinue
if ($nugetProvider -eq $null -or $nugetProvider.Version -lt [Version]"3.0.0.1") {
Write-Host "NuGet provider is not installed or the version is less than 3.0.0.1. Installing NuGet provider..."
Install-Module "PowershellGet" -Force -confirm:$false
Install-PackageProvider -Name "NuGet" -Force -Confirm:$False
Write-Host "NuGet provider installed successfully."
Write-Host "NuGet provider is already installed and meets the minimum version requirement."
} catch {
Write-Error "Failed to install NuGet provider: $_.Exception.Message"
exit 1
if (-not (Get-Module -ListAvailable -Name "FU.WhyAmIBlocked")) {
Write-Host "Module 'FU.WhyAmIBlocked' not found. Installing from PowerShell Gallery..."
Install-Module -Name "FU.WhyAmIBlocked" -Force -Scope AllUsers -AllowClobber
Import-module -Name "FU.WhyAmIBlocked"
Initialize-FUModule
# Import the module
Import-Module "FU.WhyAmIBlocked"
Write-Host "We are going to need python for this so, please make sure you have python deployed for machines being upgraded via WUA so we can see what the issue is."
# Lets now run the FU Why Am I Blocked powershell against the Panther install logs
#We also need to put the Pythong file SDBUnpacker useses.
$myDownloadUrl="https://raw.githubusercontent.com/TheEragon/SdbUnpacker/refs/heads/master/SdbUnpacker.py"
Invoke-WebRequest $myDownloadUrl -OutFile 'C:\Program Files\WindowsPowerShell\Modules\FU.WhyAmIBlocked\1.0.0.9\SdbUnpacker.py'
Get-FUBlocks -ProcessPantherLogs
$FUBlocksContent='C:\FeatureUpdateBlocks\*\Results.txt'
Write-Host "Please review the FU Blocks Content"
Write-host "It is recommend to correct the root cause vs using a Block."
Get-Content $FUBlocksContent
Write-Host "We will now go ahead and generate the reg keys to import to enable block overrides"
$BOPath="C:\BlockOverRide"
if (-Not (Test-Path -Path $BOPath)) {
New-Item -ItemType Directory -Path $BOPath
Export-FUBypassBlock -Path $BOPath
Write-Host "Please review the registry files in $($BOPath)"
Write-Host "Please note, we are not responsibile for any damages caused by using a block override."
}else {
Write-Host "$errLogPath not found`n"
}else{
Write-Host "It appears we have upgraded, version build shows as $($CurrentBuild) is > 22000"
Write-host "Refreshing System Detection Information"
Refresh-ComputerSystemInfo
"test" {
#Returns true or false if the Current Build should be upgraded, or has upgraded.
$CurrentBuild=Invoke-ImmyCommand {
return $false
}else {
return $true
return $CurrentBuild
"get" {
$CurrentBuildNumber=Invoke-ImmyCommand {
$CurrentBuild=[int](Get-ItemProperty -Path 'HKLM:\SOFTWARE\Microsoft\Windows NT\CurrentVersion').CurrentBuild
return $currentBuild
return $CurrentBuildNumber
