Can someone elaborate a little further on the steps needed to activate Ninite?
Under preferences:
Enabling this integration provides a new software type, Ninite . If enabled, you must upload a copy of NiniteOne.exe under My Software .
When installing software through Ninite, NiniteOne.exe will be added to the computer if it is not already present.
I did this, but is it supposed to be a certain name? The file itself is named NiniteOne.exe, but what about the software package?
I’m obviously missing something because a task needing Ninite reports:
9:34:01pm
WinDirStat: Getting installed version from Ninite [WinDirStat]
9:34:01pm
Software detection failed: Failed to install Ninite
