Hello,
I recently contacted Construct Connect support about an issue with their software On-Screen Takeoff and found that they are having issues with their MSI package installer for this software. With the current MSI installer it does not allow connection with their QuickBid package and defaults to the sample projects every time it opens. This is likely due to the “re-configuring” screen that runs each new instance. They said that the fix was to install using the EXE package located here (direct link here). Can you please modify the script to pull from this location for the download of the software for this specific version?
