Would love to have a feature where we can prioritize a specific script during on-boarding.
EX: I’m onboarding a computer and I need to remote into it but the script to install ScreenConnect is all the way at the bottom.
It would be great if I could prioritize that script to run asap during that particular on-boarding without changing the order globally.
Look at “Library > Deployment Ordering”, that is how you give priority to specific tasks.
It’s worth noting that onboarding tasks (tasks with “Onboarding Only” checked in the deployment), regardless of ordering, will always run before general maintenance tasks. So, if you need it to be the very first deployment that runs, you need to set it as first in the ordering page, and make sure your actual deployment has “onboarding only” checked
