Revit 2025 deployment issues
Hey all,
Is anyone else having issues deploying Revit 2025 on devices that already have other versions on Revit installed, The deployment logs gave a random error, however if I ran the command manually on via command prompt on the device it installs with no errors:
2025-01-16T16:06:10.104 [Deployment: 55268, single] [JUBB-1LFC INFO] Deployment started…
2025-01-16T16:06:43.143 [Deployment: 55268, single] [JUBB-1LFC INFO] Skipped install for bundle with UPI2: {686CE2A3-7C33-3AD5-806A-75A6E648117F}
2025-01-16T16:06:43.145 [Deployment: 55268, single] [JUBB-1LFC ERROR] Deployment initialization failed for Upi2: {686CE2A3-7C33-3AD5-806A-75A6E648117F}
2025-01-16T16:06:43.330 [Deployment: 55268, single] [JUBB-1LFC INFO] Deployment exits
We have a client that was having issues getting 2025 to even install manually. I believe there is an issue with 2025 on the vendors side right now.
If you find a way around this though I would love to hear how. And if I find anything I will let you know as well.
So I managed to solve this particular issue by making sure all versions of Revit were closed before the deployment starts, I’m not sure if this is always the case or just 2025 that has this issue.
Hey Simon, this has always been an issue with Revit (other Autodesk apps as well). We typically ask a user to make sure all Revit is closed if we are deploying it during the working day and the endpoint has not been rebooted. Otherwise it will fail everytime.
Why must the endpoint not have been rebooted? Wouldn’t rebooting it kill all revit?
