Please consider adding the software from Revolution Design to the Global library. They have a few really good add-ins for Autodesk Revit. There pre-configured deployments need configuration files to install properly, and I am not savvy enough to create the scrips needed to make a custom install.
Below is a link to their software.
Thanks.
Silent install instructions.
