Running multiple tasks against a Tag
Hello Immy.bot Community,
I’m using a tag to target three different companies and I want to add multiple deployments of the “Configure Wireless” task in case users move between sites. However, when I try to create multiple deployments of the same “Configure Wireless” task with different SSIDs, it prompts me with an error saying there’s an existing deployment. The “Fix” option reverts the task to a previously saved version, and the “Replace” option deletes the other SSID configurations. It would also be helpful if I could input multiple SSIDs within a single “Configure Wireless” task. Is there a way to resolve this issue?
