Currently when scheduling deployments its either rebuilding a global deployment or creating a cloned local deployment with client specific information.
There should be an option where if selecting cross-tenant or single tenant the specific tenants deployments that are already configured should be options to choose from directly.
Example is QB Updates with client specific variables for licensing and product key. I should be able to select the already created deployment for a tenant to update it on a weekly/monthly cadence.
The only option right now is to create a clone and bake in the variables as a local deployment.
