Similar to the Remove Unkown ScreenConnect task, this would ideally be a task that allows you to list Known Administrator accounts that are approved to exist on a machine(s).
The task would then determine all users that are an Administrator on the given machine, refer to the list provided on the Deployment task and remove any conflicting users from the Administrators group.
