Looking for any tips on getting the s1 uninstall working properly if anyone has any advice.
I ended up modifying the dynamic integration script that’s floating around global to do this.
Fair warning, the whole integration is a bit wonk still, which is likely why it’s not published yet.
Let me know if you make any tweaks ![]()
Integration Snippet:
# supports retrieving a tenant uninstall token
$Integration | Add-DynamicIntegrationCapability -Interface ISupportsAgentUninstallToken -GetAgentUninstallToken {
[CmdletBinding()]
[OutputType([string])]
[Parameter(Mandatory)]
[string]$agentId
Import-Module SentinelOne-Local
Write-Host "Agent ID: " $agentId
$response = Invoke-S1RestMethod -Endpoint "agents/passphrases?uuids=`"$agentId`""
Write-Host "Agent: " $response
Write-Host "Passphrase: " $response.passphrase
return $response.passphrase
Integration Agent Uninstall Script:
$Passphrase = Get-IntegrationAgentUninstallToken
$Uninstallers = Invoke-ImmyCommand { Resolve-Path "$($env:ProgramFiles)*\SentinelOne\Sentinel Agent *\uninstall.exe" }
Write-Host "Found:" $Uninstallers
$Arguments = @"
/uninstall /norestart /q /k `"$Passphrase`"
$Logfile = New-TempLogFile
foreach($Uninstaller in $Uninstallers) {
$Process = Start-ProcessWithLogTail $Uninstaller -ArgumentList $Arguments -LogFilePath $Logfile
Write-Host "ExitCode: $($Process.ExitCode)"
