We’re an MSP in Australia and we are getting PCs deployed with US settings. Is there a way I can stop it from applying these US settings as they generate extra work for either the techs or Immybot itself.
We do have international users, but as you can imagine, most of our machines are getting deployed in Australia
We are still transitioning tenants over to Immybot but have noticed that the machines that are built via Autopilot or Manually do not have this issue. Also the time is correct when checked before deployment.
Basically, no. I worked with their support on this specific issue for ages and they could not resolve it. We have a set of powershell scripts we paste into the first admin account then a settings change which fixes it on the current and future logins but its manual intervention. Super frustrating as if you are at the OOBE and choose Australia manually it will do everything itself, but the Windows backend won’t let Immybot do the equivalent of whatever happens when you choose the country.
Be good if it were that simple, you would think they would know that and it would be an easy fix to choose a location for the ppkg file if that’s all it was.
No issue. We run one of these depending on whether its NSW or QLD (one state observes daylight saving the other doesn’t, very annoying). Then afterwards we also need to go to Region / Administrative tab and tick both “copy your current settings to Welcome Screen, New User Accounts”. If we don’t do that it doesn’t use it on any new profiles made.
