Suggestion for Alerts
It would be helpful to have the alerts go to a Teams channel, slack, or even a ConnectWise service board when Immybot gets done
I’d like to be able to configure a system tray popup or a something that can show up on the task bar with Maintenance tasks are running so they know its on purpose, and include branding to help assure user base.
Thanks for bringing this up. We talked about it internally today, and part of this may be helped by the new dashboard since it should make failures and items needing attention easier to see without relying only on notifications.
For the alerting side, would something like an Azure Service Bus that you control meet the need? That would let Immy publish events out so you could route them where you want without us having to build every destination directly.
If not, which built-in destinations would matter most to you first, like Teams, Slack, or ConnectWise?
Hi Derek,
I like the Azure Service could work for Emails but Teams or Connectwise or all 3
