Synology Drive Configuration for mass deployment
I see that the Synology Drive Client is already in your library of software.
I am in the process of trying to do a mass deployment of the drive with vary specific configuration options. Synology give some instructions on how to format a Json file for the configuration wizard to run. I was wondering if Immy.bot has the ability to create a custom configuration task to complete this?
Synology Drive Mass Deployment instructions
