Recently had a task get weird because I had duplicated the URL Shortcut Template Task a while back and set the parameters manually in the task, but kept the global script. The global script has since changed and uses the script parameters now. This was causing errors during deployment, and took a bit for me to figure out why it was happening. Just wondering if we can get some sort of notification when creating a deployment that something is up with the parameters.
