Hello, with the recent Xen VM Driver vulnerabilities, we were looking at ways to automate the updates and installs of the Citrix XenServer Virtual Machine Tools.
We figured there are probably a fair number of users using the Xen Hypervisor that would benefit from this software being in the global catalog.
The VM Tools package supports silent installation as well as setting parameters for if drivers should be installed and if auto updates should be enabled for the tools and the drivers.
The XenServer VM Tools for Windows can be found on this page:
And the KB on installing it (with supported switches) can be found at:
